l0nesailor
Hi there. I'm another guy that just bought a 2226B to get addicted to. It came from a Goodwill and is pretty much spotless on the outside and, after a lot of reading, has some typical mono stick crackle and balance issues that deOxit will hopefully handle.
The problem I can't clean away, which may be something I am doing, is that when running my AT-LP-120 into the 2226B my entire desk starts to rattle. To test I figured out I could cause this by just putting the needle down. This occurs in phono and AUX input (using line for aux). This does not happen when plugged into Tape 2 using line output on turntable. It is more pronounced with actual track is playing and progressively gets worse.
I also get a faint bleed over from phono and aux into every other input. Any ideas?
I posted a video that may help...Thanks in advance.
