Marantz 2230 Antenna question
Denver jt
I just purchased a Winegard 6010 fm antenna to improve FM signal reception. Does anyone have a current photo that they could post with how I hook it up to my Marantz 2230? The antenna has a coax output. I have the manual and I have searched the web and I am still a little confused???? When I attached my current dipole to the 300 ohm inputs exclusively it wasn't great. When I attached one to the 75 and one to the "middle" 300, it seemed to improve. Now that I'm upgrading the antenna, I really want to make sure I don't screw up the connections....
I think if I saw a picture of the receiver connections, it would help clear it up for me. Thanks!!
Thanks so much! Part is ordered and I plan on installing the antenna in the next few days. I'll update the thread soon.
Just to add my $0.02, I was stunned to discover that "directional" FM antennas were almost a thing of the past. The stations I'm trying to pull in require more gain and front-to-back ration than omnidirectionals were designed to give. If you're in a metro area and all the stations you want to listen to are local to you, then the Winegard you selected will be great. But I ended up going with this inexpensive directional model which I may mod into an even tighter, more directional pattern:
http://www.mcmelectronics.com/product/30-2460
I also added a Channel Master antenna rotor so I could pick up stations up and down the west coast of Florida. Have fun!
