Audio_MGyver
Hello,
I'm new to the forum and hoping someone can help.
There two issues with my Marantz 2230 (thrift store find). So far I've replaced all lamps with leds, replaced the tuner cord and fixed one of each of a cap, resist, and rf coil. I also cleaned all boards with air and 99% alcohol. Before the work, I had an Aux issue but everything else worked. Now, I've introduced an am issue.
First, the Aux issue. When I turn the selector switch to Aux, it blows a 3amp fuse (front right top where there are 4 fuses in a row). I purchased new 3amp fast blow fuses and I can replicate the issue. Clearly, the previous owner had an issue as the fuse I replaced was blown when I got it. All panel LEDs work great, tuner light, meter light and stereo light and I can switch from am to fm to phono to tape without issue. But once I switch to Aux, it blows the 3amp fuse every single time.
I'm new to this and having a blast (when I'm not pulling out my hair)! I've looked to Audiokarma each time I have an issue but I can't find this one. Not even in a Google search of any receiver brand. Reading the 2230 service manual, it seems the wires go straight from the Aux jacks to the selector switch. From what I can trace by eye, all soldering seems ok. But I really do not have any desire to start snipping wires just to remove boards to see better and then have to solder them back on. Could this be a grounding short issue either with the selector switch or a bare wire where I cannot see? Or does it seem more like an ouput board issue (not sure how though).
Second, before cleaning the unit, the am tuner worked. I could hear sound and radio stations were coming in. After cleaning and waiting a few days there is no sound at all on am and the fm tuner meter is less responsive. I read one forum where someone said the fix is to resolder all of the board points on the bottom of the receiver but this is not the issue. Another person said that they had the exact same issue as me (exact) and after a month of using it daily, everything slowly came back to life. I'm hoping for the same but if not... Any ideas?
Thank you for any and all help.
