Marantz 2230 - Champagne color/Engraved
krblgc
Recently got a 2230 with champagne faceplate and engraved lettering. Serial number is 1041. No year/date engaved inside the chassis. Anyone can help me regarding the history of this 2230, year of manufacture, etc. was this manufactured during the transition years from champagne faceplate to silver? Some of the black lettering has faded or one. any tips on what to use to retrace and put black paint on the engraved lettering? thanks for your help!
The 2230 started with serial number 1001. Yours would be the 41st unit built out of something like 185,000. Pretty special unit. Probably from 1972. If you remove the metal cover, there is usually a date stamped on the top right of the chassis.
The 2230 in this pic is on the bottom left, it's not-engraved and a bright gold color:
It was sold in early 1972:
Every champagne one I've seen, came from 1971 so far.
hi Steven. i did opened it and no year or date stamped on the chassis. my other Marantz have those.
I have serial number 1308 in the 2230. It is champagne engraved. I restored it completely, but don’t remember if it had a date on the chassis. I’ll have to open it and take a look. Yours being #41, they likely were still ironing out the process.
There are no dates on the two early 2215 champagne-engraved I have.
The serial is stamped in three places on the early ones, the tag on the back, underneath the transformer mount:
Under the power supply, this one is really sloppy, my other 2215 has a crisp stamp in this location:
If you have a champagne face plate, and no <5000 serial number stamped on the chassis in those places, it's probably been modified.
EDIT: Opened up 2230 #5468 and found a date right where it usually is found:
Looks like January 24th, 1972 is when #5468 was born, not engraved and not champagne any longer, at this point.
I'll have to check mine. I'm pretty sure it is legit because the P550 Muting Control board only had about half of the perfed area filled in with components. My later 2230's have the full complement of components. I've been told that was a very early P550 board. And it works just fine. Makes you wonder why they needed more components. :D
This was it after restoration. P550 in top left area. It was very dirty to start with and had been butchered with wrong parts and parts installed backward.:( And I notice no stamp on top of chassis like you said.
Yours has no date stamp above the tuner gyro, the brown PCB's with the white M's, a gold chassis, and the orange mesh lead covers - yours looks every bit original champagne-engraved to me, nice! Been looking for one.
yes, i noticed that too that it was half populated. the internal chassis also is gold-ish color. and no date stamp on the top of the tuner gyro. might be one of the earliest build.
Anyone have any tips or suggestions for restoring the black ink or re-drawing them with ink inside the engraving?
I have a Marantz 2230 bearing the serial number #1037 - it is (of course) with a champagne faceplate with etched lettering. it was originally imported to Denmark, where it is now. as far as I have found out so far - it may be the earliest model 2230 to be highlighted here.
I don't remember if it is having a date stamp somewhere.
The serial number is stamped several places - under the top cover - on the chassis and a few more places.
regards
Freddy
The chassis is gold tone annodized also...common with very early 2230's. I've got a 2230 and a 2270 with the etched "gold" faceplates. The 2245 also came that way.
