Marantz 2230 coupling capacitors
2877
I posted this a few days ago and listed the wrong model number. The correct is 2230
I'm rebuilding my Marantz 2230 and the recommended coupling capacitors from the AK list are no longer available. Can anyone recommend a suitable replacement?
Thanks
Bob
For the coupling caps the Nichicon Gold Tune 2200uF/80v fit the original clamps.
For the filter cap you can use a Nichicon Gold Tune 4700uF/80v. These are 35mm diameter, the originals are 40mm. A Kemet 35mm clamp fits in the same location and matches the original clamps cosmetically.
This is a conservative approach using values that nearly match the original caps.
