Hello, recently I finished a full recap of both the left and right p750 amp boards on my marantz 2230 as well as replaced the three small transistors on each board (not the snowflake heatsinked ones or output transistors.) This was about three days ago and I have used it a fair amount since with no issues. Everything seemed to be fine until today when I went to turn it off I noticed that the output transistors that control the right speaker were very very hot while on the left was completely fine. After removing the top I determined it probably isnt a single bad transistor, as they both get equally hot on the heatsink. The varistor wires were not broken during the recap, and it is making solid contact with the heatsink. The speakers themselves are fine and aren't drawing excess current. Right is connected to remote right and left is connected to main left. The amp had only been on for about 7 minutes and both channels still sound equally nice even after the ordeal.
The weird part is that I have been unable to replicate the issue. I ran it for about 20 minutes at a fair intensity after the fact checking back every few minutes to make sure it wasn't getting hot and it stayed completely cool this time. Could it be the bias is set improperly for this board? I don't feel great running if its being temperamental like this. Does anyone have any ideas of what it could be or where to start? Thanks for your help!
