Hi everyone,
I’ve been working on restoring the P800 power supply board on my Marantz 2230, and I’m currently stuck with a voltage regulation issue that I haven’t been able to resolve.
The main problem is that J808 is sitting far too high and cannot be adjusted. According to the service manual, J808 should be adjustable to 35.6 VDC, however I am measuring ~43 VDC on a dim bulb tester, and the trimmer R810 has no effect at all — the voltage does not move in either direction.
Below is a complete list of parts on the P800 board, indicating which parts were replaced and which were left original.
Any insight into what could cause no regulation action at all at J808, especially with these voltage readings, would be greatly appreciated.
Thanks in advance for any help.
Resistors
- R801 10 Ω 1/2 W (no replacement made)
- R803 3.3 kΩ 1/2 W (no replacement made)
- R804 10 Ω 1/2 W (no replacement made)
- R805 4.7 kΩ 1/4 W (no replacement made)
- R806 1.5 kΩ 1/4 W (no replacement made)
- R807 3.9 kΩ 1/2 W (no replacement made)
- R808 27 kΩ 1/4 W (replaced with 27 kΩ 1/4 W)
- R809 5.6 kΩ 1/4 W (replaced with 5.6 kΩ 1/4 W)
- R810 4.7 kΩ (no replacement made)
Capacitors
- C801–C802 500 V 0.01 µF (no replacement made)
- C803 63 V 470 µF (replaced with Nichicon 63 V 1000 µF)
- C804 50 V 330 µF (no replacement made — part yet to arrive)
- C805 16 V 470 µF (replaced with Nichicon 16 V 470 µF)
- C806 50 V 330 µF (no replacement made — part yet to arrive)
- C807 50 V 3.3 µF (replaced with Nichicon 50 V 10 µF)
Semiconductors
- H801 2SD315 (replaced with MJE15032G)
- H802 2SC696 (replaced with MJE182G)
- H803 2SC1213 (replaced with KSC2383YTA)
- H804–H805 SIB-01-02 (replaced with UF4005)
- H806 BZ-140 (replaced with 1N4744A)
- H807 WZ-071 (replaced with 1N4737A)
- J808: ~43 V (should be 35.6 V, not adjustable with R810)
- H802:
- Collector: ~46 V
- Base: ~43.6 V
- Emitter: ~42.9 V
- H803:
- Collector: ~43.7 V
- Emitter: ~7.4 V
- Base: 0 V
