2230 cap questions...source for the chassis oil/paper caps and a SM typo
Ping, CAT, BK, et al,
If this is covered in the thread, I missed it
Is replacing the chassis oil/paper caps generally considered to be not an issue? Have not noticed much mention of these things.
Are "oil/paper" a relatively short lived cap? especially compared to ceramic or most of the other types. Correct or not?
Have been looking for the:
C005-006 "OIL/PAPER" 0.020uF 600 VDC
C010...... "OIL/PAPER" 0.033uF 800 VAC
Good sources for oil/paper? The tube orientated "guitar amp" and "vintage radio" web sites have NOS oil/paper caps CLOSE to the needed values, but seem too low on the voltage spec. Saw some new manufacture, but I think the wrong range of values and pricey.
NOS, "new old stock" seems a poor choice if these caps degrade faster with years.
Can another type of cap be substituted for oil/paper safely, considering the almost direct connection to line voltage?
What are the characteristics of oil/paper that make them ideal for filtering voltage/amperage coming into the chassis?
Reading about failure modes for different cap types...flash over, tendency to fail "open", short out or increase resistance...is that a factor in using oil/paper?
TYPO in my 2230 SM as to Cap C001. "C001" is listed as a "Elect." but NO value is given, just a blank space. Found "C001" on the schematic between the inputs to the "Signal Strength Meter" leads. Value on the schematic is shown as "3 3uF" 6volt. Is that 3.3 or 33uF?
Typo, but though it worth asking.
Thanks.
Pete
Thanks.
Pete
Either way I hope you are having fun doing it.
