Hi all,
I just finished recapping my 2230 and making what adjustments I could. The idle current adjustment went fine, but I have an issue with the voltage adjustment. According to the service manual, I'm supposed to measure voltage at J08 (essentially the speaker terminals as far as I can tell) and adjust trimmer R810 to a reading of 35.6 volts. My reading was between 15 and 16 volts no matter how I adjusted the trimmer. The trimmer was the original, and didn't have that really touchy action that trimmers tend to have. So, I replaced the old trimmer with a new Bourns multi-turn trimmer in hopes of an easy fix (4.7K, Mouser part # 652-3339P-1-472LF, http://www.mouser.com/Search/Produc...virtualkey65210000virtualkey652-3339P-1-472LF). But no such luck. Again, no matter how I adjust the trimmer the voltage is no higher than 16 volts.
Where do I need to start testing things to find my problem?
I started working on vintage receivers in part to learn some electronics skills. I've recapped several receivers so far and have developed pretty decent soldering skills, and I'm getting better at reading schematics. So, I guess this is a good next step in the learning process. I've got another receiver with some more complex problems, so this should be a good step before I tackle the harder one. Any help would be greatly appreciated.
Allan
Allan
