jfriedrich
I'm having a similar issue to that described here: http://audiokarma.org/forums/index.php?threads/marantz-no-lights.557250/#post-12217879
But mine is not simply a fuse out, as my F802 fuse keeps blowing. I'm using the properly rated 250v 2amp fast blow fuse.
My AC voltage J810/J809 is 8.4v. Is that too high? The thread posted above seems to suggest it's higher than it should be.
I just redid my lamps just before this happened. It was working fine for about 30 minutes before I lost my panel lights. Unit functions fully, just no lights as everything past the F802 fuse is not getting power.
