MARANTZ 2235 no sound
Joe Matz
So I just bought a Marantz 2235. All lights work. All input selector lights work. No obvious damaged components. No sound to speakers. Main in pre amp rear seems to be fine. No relay click on power up. I am not a techy but I have done some research on this problem. I am getting all sorts of readings with my multimeter on diode check with the transistors out of circuit. . Please see both uploads with the readings I observed. I am wondering if I should just replace all 4 transistors or is there other problems that will damage the new transistors ?? Any comments would be appreciated.
