Hi All:
Not even sure to start looking on this one and I'm certainly not an electronics expert - just a lover of vintage electronics and a basement hack.
I recently picked up a 2235B that works fine and sounds perfect until it gets to roughly 1/2 volume. At that point it kicks the speaker relay and the there is no volume at the speakers. Once you turn the volume knob down a bit, the speaker relay clicks and the sound comes back.
Trying to isolate the problem between the pre-amp and power amp section I plugged the pre-out out of my 2235 directly into the main-in of the 2235B - same thing happens at roughly the same volume setting on the 2235 - so that sounds like the power amp on the 2235B is doing this.
Any thoughts?
Thanks much
Chris
Any thoughts?
Thanks much
Chris
