Traverso
Thank you for the feedback
- For the differential pair I used KSA992FBU, Hfe matched
- For H706 I found there a defective 2N1711 from Texas, I replaced by a 2N1711 the pin out is ebc; the recommended 2SC875 is surprisingly ebc as well,
I gave up with BC140,
- the H717 andH730 diodes have been changed as you mentioned by two 1N4148 in series,
- the zener diode H715 was tested ok as well as the H005,
- the output transistors have been replaced: H714 and H712 have been replaced by by MJ21193 and MJ21194
I have no explanation why I found - 0,32V on base of H708 and H710 where it should be 0V.
Any idea?
Any idea?
