Marantz 2235B Pre-Main, Idle Current, and Other Questions
What amp are you referring too? Those were to show the configuration of pins they may not be proper resistance for your application so confirm with the original specs on schematics!
Since the thread was about the 2235B, I assume that's what we were talking about.
I didn't order them yet thanks for the heads up.
EDIT: the 2235B uses a 200 ohm, so the correct part number is 3296W-1-204LF‎
https://www.digikey.com/product-detail/en/3296W-1-204LF/3296W-204LF-ND/1088052/?itemSeq=321275220
Again, thanks for the warning.
I posted images to show the pin configurations that are something to be aware of along with the restrictive values.There are many to chose from ... good luck
