The (+35V) power supply board does not supply voltage to the main amp section so you will not have any problem with Dc offset or bias. It supplies power to Pre-amp, tuner, and phono board. you ill have problem there.
Yup, same here. Thanks for this thread. The SM is definitely wrong.I can only get it to 29 volts instead of the 35v stated in the manual.
