ton4eff
3 years ago I did a Marantz 1060 P700 amp board replica, it came out pretty well, trying to preserve the original look/layout of the PCB. You can take a look at this old thread.
I had a few requests to do the same thing with P750 amp board for 2270/45 models. Since I don't have this board yet to use as an example for measuring the exact physical dimensions (I'm using pdf files from SM for now), I'll have a few questions about it. I'm also accepting suggestions for minor modifications, if needed for easier fitting modern parts, maybe changing some hole/slot sizes, distances etc... So thanks in advance for everybody participating in this thread!
First thing I noticed - they used too completely different layout versions of this board:
The early one:
And revised:
Hmm, so I have to make 2 boards instead of only one...
The early one:
And revised:
