JDPossible
Marantz 2245 with the left channel showing slightly less amplitude over the right. I've isolated it to the pre-amp/front end. Sign wave taken at the pre outs.
1k test tone used.
I've tried every input with exacting results
Thoroughly cleaned the selector switch with contact cleaner.
H406 & H408 shows voltages way off. Replaced with KSA992 & KSC1815. No effect on the issue.
I inspected for solder bridges on the P400 board and it looks great.
Checked all resistors on the P600 board. Disassembled the Loudness, Muting, Low Filter & High Filter buttons, cleaned, lubricated and used red Deoxit on the contacts.
1k test tone used.
