Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Maybe someone else could chip in here but I don't think you need to buy exact. Being mains voltage, I'd like someone to sanity check my reasoning.
If you want, you can make one with a 120ohm resistor (Of 1/2W or better) in series with a 100nf X2 cap. it would be a damn siight cheaper too. There's a spare tag on your tag strip to solder to.
Yes i read also i may compose one with a cap+resistor. I would prefer to have the exact 2 values in 1 component. I'll check this aternoon internet, getting closer at 100nF/100Ohms. Due to my limited knowledge i'm a little bit concerned going to less resistance than 120Ohms
It's an arc suppression "snubber" RC array. @painttoad posted a good replacement.
If faulty, it will have pretty much zero effect on the operation of the unit, other than that the power switch contacts will wear out more quickly.
