I have not replaced the lights on a 2252B, but on most 22xx receivers, it's a matter of removing the knobs, removing the faceplate, removing the dial face, which has velum taped to the back of it as a diffuser. The dial face bulbs are fuse types that are often replaced with warm or cool LED's because of their longevity and cooler running. Pop out the old incandescents and pop in the new ones. The input indicator bulbs are a little more difficult as they are bi-pin bulbs soldered to a small circuit board. They are changeable if you have good soldering skills, but you can mess up some things if you aren't careful. For new bulbs and velum, check with Randy (AK member runnindog) at irebuildmarantz.com.
