Just picked up this 2252b receiver and the relay doesnt engage 99% of the time. It will engage after an elongated period of time under “aux”. Turn up the volume under aux and it disengages. If started and engaged under “aux” once switched over to FM for example the relay immediately disengages again. What could be the issue ? Cant test via main in or pre out because relay wont engage. Cleaned relay under cover and still same situation. Set power supply to 35V as well.
