Marantz 2265 volume cuts out?
TimBabyFace
Hello I have a Marantz 2265 purchased off eBay and the volume will cut out at some volume levels. The guy i bought it off said it was most likely the relay and sent me a new one with the purchase. That being said it dosent seem to be the problem any information would be greatly appreciated.
Tim
Have you applied De-Oxit to all the controls and switches?
The Idiot's Guide to Using DeOxit (revisited) | Audiokarma Home Audio Stereo Discussion Forums
Sometimes a TAPE MONITOR or SPEAKER SELECT button will cause this
when it drops the volume, try working the switches and buttons CAREFULLY
DO NOT TURN THE VOLUME UP ALL THE WAY AND POKE AROUND
KEEP THE VOLUME LOW
keep us informed
you know I have not actually just the knobs and switches where else should I apply it ?
Ok give me a minute and I will get back to you. Thank you btw
KEEP THE VOLUME LOW
keep us informed
Ok so I've got the tape and speaker switches as clean as I can with deoxit d-5 and still the same results.
Could be simple, could be a problem
process of elimination
I assume that you dis-assembled the unit to gain access to the inside where you sprayed the d-oxit per instructions?
Does it always drop out at the same place in the volume?
Both channels?
with headphones?
all inputs?
with different speakers?
with connecting the speakers to speaker B?
one more question
At what volume level does it occur?
Both channels?
with headphones?
all inputs?
one more question
It seems to drop out around I guess you would say at 4 or quarter the way and yes all output even the headphones. It's got me scratching my head for sure.
Does it return later on in the volume...say at 5?
Does the volume return if you turn it back down?
put the balance to full one side...same?
you did d-oxit the volume control?
Yes I used deoxit on the volume. I also tried one side and then the other and sadly same results
sounds like the volume pot
with power off, measure the volume pot ohms and see if it drops out
hit it with deoxit from inside the case again. flood it! there are small opening you can find to get the stuff inside the control
Then pick up the whole unit and 360 degree it to get the d-oxit everywhere in the control
slowly work the control back and forth, never do it fast or aggressive
that concludes the easy stuff...
hit it with deoxit from inside the case again. there are small opening you can find to get the stuff inside the control
Ok I'll give her a shot give me a minute and I will get back to you.
So this came out of the volume pot and I wouldn't believe it if I didn't live it but problem seems to be solved. I owe you a cold one thank you so much for everything.
Tim.
jeez, who woulda thunk it
part of the carbon trace or some FOD
glad you got it working
That 360 thing is the real trick
MY job here is done...UP UP and AWAY......
You should subscribe to AK for an even better experience
He's off to help another audiophile in distress!!!
Thanks again .
I know what its like, vintage audio can be a challenge
I recall when I first learned which end of a soldering iron to hold
I am concerned as to what the debris is?
Probably the shipping experience played a part in dislodging or maneuvering the object into the control path and the flood and 360 washed it clear
This pot is clean
The original owner/seller will be relieved
This pot is clean
Well I'm given her a 4 hour bench test and no problem's so far as far as the gunk it looks to be food ? Very strange regardless thank you thank you I'm very happy I came across this great site. And a great super hero lol.
Just my 2 cents, just about every receiver I purchased had a similar symptom where either one or both channels dropped out.
Since you cleaned the switches, try tapping the relay with your fingers to see if the sound returns.
