Working on a marantz 2270, replaced the power switch, found shorted S40442 output transitor on right channel. I replaced both npn and pnp on right side with onsemi mj21193G/94G. powered up on dimbulb everyting is working, came out of protect. set dc offset just fine but the bias is all over the place. the pot which I know is probably shot and needs replaced is soooo touchy. Measuring accross each .2 ohm resister (r788 r789) I get two differnt values. they are about 3-6mV off from each other. Left channel is dead on. What am I missing here? Ive read that bias should be 5mv accross each resistor for a combined 10mV accross both.
