Yoast
I have a hiss or crackle or static on both channels (but not at the same time) when using the marantz 2270. I switched the cables left and right channel and the static appeared on both channels. (not simultaneously) The amp was recapped and serviced just recently because of this but the technician could not find any problem and now it has come back. Ironically the person I bought it from had it recapped as well (a year ago- with shitty caps) so I had it checked just in case and the technician I used replaced the caps with ELNA caps.
When I touch the main in pre out jumper on the back of the amp it gets worse and I can produce it. Also it happens mostly after warmup or around half an hour of playing and It happed when I moved the speaker wire as well.
What can it be?
Thanks!
What can it be?
Thanks!
