TellMeWhy
Hi guys, I am replacing the headphone socket on my 2270 as the original fell apart in situ... My question in what to do about the two 47 ohm resistors that I believe were wired to the + L and R channels in the old socket and to a common ground. The new socket is a Monocor one (apparently the suitable replacement) but with 3 pins only (common ground and left / right I think).
Can anyone offer any advice on the resistors and correct way to solder it? Should the resistors simply sit in series along the signal path and the black wire go directly to the socket ground?
Thanks as always! Jon
