MARANTZ 2270. HELP
jFF_Bulbo
Hello
I recently tried to recap tonee board P450. Once i finished, the left channel sounds low and dirty. Unit was working fine before i Recap, so, i have done something wrong.
To replace capacitors i installed MPK caps With Tha same values. I resolder and Soublette checked my work.
Before:
After
And i really wish yo retore my Marantz
Thank you in advance.
Well first off, you really didn't need to replace anything on that board.
Second, check everything again. You obviously put something in wrong or made a solder bridge if it doesn't sound right after you worked on that board. Check all joints you soldered.
Make sure you replace the ceramic caps with equal value COG type ceramics. See next post with cap list for tone board.
Probably nothing, but Leestereo’s C455/456 are blue C0G ceramic caps. Yours look like film caps. Are you sure of the values?
