tkrilly
I got myself a 2270 in pretty decent shape a couple of weeks ago, dead quiet at full volume when no input signal present, with only a couple of burnt bulbs. Unfortunately I couldn't resist the urge and went into fixing the lights, then continued by replacing all the electrolytic caps on the P800 board (C801-C807, C810 with Nichicon type), followed by the replacement of the two big caps and a relay for a good measure. Alas, after I powered it up again I noticed a substantial noise/hum that changed if I touched the chassis, which made me believe I was dealing with some sort of a ground loop issue. The noise was most pronounced on the phono input. I tapped all the replaced components to see if there was a poor solder job done somewhere to no avail. I uploaded the video where I switch between phono and aux inputs here:
The noise and its changes can be clearly heard. Prior to that, I adjusted the R809 to set the voltage level to 35V, and measured the noise on it, which was on 10mV level (please see the attached scope pics here https://drive.google.com/drive/folders/1EpgpkBAqkr4Utj02Q2rcMPBGbNJ-eZWp?usp=sharing ). Then I a checked the voltages on BCE of the following transistors (SM reference values given in brackets):
H803 B 13.8 (14.2) C 30.5 (32.6) E 13.2 (13.5)
H805 B 35.6 (35.7) C 44.2 (44.0) E 35.0 (35.0)
H806 B 7.8 (7.8) C 35.6 (35.7) E 7.2 (7.1)
H808 B 0.0015 (0.0) C 0.9 (1.25) E 0.0 (0.0)
H809 B 1.25 (1.25) C 1.0 (0.8) E 0.7 (0.7)
H810 B 0.7 (0.7) C 1.0 (0.8) E 0.0 (0.0)
As far as I can tell none of the values are too far off, except maybe for H803B. At this point I am lost on how to proceed and would really appreciate the suggestions and expert opinions of other AK members who have done such troubleshootings in the past.
Eternally grateful,
Jurij (Yuri)
Eternally grateful,
Jurij (Yuri)
