AngelAT
Well-Known Member
Dear all,
I have been working on the power amps of my 2270.
Both power amps were taken out of the unit. Replaced the output transistors h001-h004, h758, h759, h751 and the two electrolytic caps - c759 and c760.
Idle current and dc-offset adjusted.
Then both power amps returned into the unit and the right one has a problem - severe distortion. Again taken out for tests and perfect sound. The only difference being that the power amp is not grounded to the chassis (just connected via the two big filter caps).
When I placed it back I found that if I completely isolate the right power amp from the chassis the sound is again ok.
Left power amp is grounded to chassis and sounds perfect.
Did you guys ever had such a problem and can you suggest a remedy?
Thanks in advance!
BR
Angel
Thanks in advance!
BR
Angel
