Marantz 2270 recap Help
jFF_Bulbo
Hello AK'ers.
I hace a 2270 Unit .recently serviced. Many new pieces.
I like to recap preamplifier section, so, according to the post of LEESTEREO about, I got some MKP capacitors With the same values that the actual capacitors instaled. I used the user's manual part list.
I'd like to know if they are apropiated for that
I also hay a pair of 0.33uf 250v tropical fish capacitors, i think use them yo Replace 0.22uf 50v (c401 and c402). Should I?
Regards!!
Not quite sure what's going on...
You shouldn't need to replace any film or ceramic capacitors.
Keep values the same, changing them will lead to more bad than good in most cases.
Yes, the red WIMA film on caps 3.3uF or less is the new standard IMO. They're cheap & easy to install.
I also agree the Mundorf's are a bit excess in cost w/not enough ROI. I'd stick to the big brown/khaki ones.
I've used a few of those to great success.
Well, actually I can't say that other caps wouldn't have sounded as good - but I am certainly happy with the result.
...I also hay a pair of 0.33uf 250v tropical fish capacitors, i think use them yo Replace 0.22uf 50v (c401 and c402). Should I?
The "tropical fish" capacitors are polyester film types, hence essentially the same as the stock polyester capacitors at C401/C402.
The ceramic capacitors the OP refers to are in the signal path of the tone control circuit (Board P450); recommended replacements are C0G types.
Pictures are from [URL="http://audiokarma.org/forums/index.php?threads/leestereos-restoration-and-upgrade-of-a-marantz-2270.793805/"]Leestereo's Restoration and Upgrade Of A Marantz 2270[/URL]
Here is a list of manufacturers part numbers for Leestereo's 2270 P450 Tone Control board upgrade. Corrections welcomed.
jFF
Are you into the board for another reason, like repairing something? Otherwise, I would leave the non electrolytic caps alone. That's just my opinion as lots of people like to do a rebuild and there is merit in that activity.
But if you must, keep the values as close as possible as big changes sometimes alter the original design of the circuit and can have unintended affects. You can get away with altering values for filtering, such as using a 50v instead of a 25v cap.
Cheers
jFF
Cheers
Hello
I'd like to have a 2270 Unit like the ones i see in this and other fórums. I got MKP caps, same values as the actual y installed. I think they are Old, but news.
So .I really want to recap the tone board
Any suggestions?
Hello
Any suggestions?
Use WIMA films for all values 3.3uF and less. That’s most of the old electrolytics. Use new electrolytics for values over 3.3. See Dingman’s photo above with all of the red caps.
Edit: C401 and C402 should be films like Panasonic ECQ series (again, see Dingman’s photo
I ran into some mylar caps on the p400 board that tested value wise ok but the esr tester said 8 ohms - way too high. I replaced the .22uf's with Wimas .33uf and the volume actually went up for the same setting.
