Marantz 2270 Relay issue
Sounds like you have one good amp and one bad one. Time to troubleshoot the bad one. I just went through this on a 2270, and I am not much help. It was a lot of trial and error removing and testing parts. Turned out I had installed the wrong transistors in the diff pair. If you have recapped that board or replaced anything, check your work first - proper components, polarities, solder joints, etc. if all is good there, you might have to start testing transistors starting with the outputs and work back. I think the blue wire is the left amp, but check just to be sure.
yes the left channel. I'll start the rebuild process and update. I've already tested the outputs transistors and they seems to be fine.
