Jerwardemy
I posted in the Vintage Solid State and Marantz forums and it was suggested I try posting here to see if I could get any help...
Ok, so I had a fuse blow on my 2270 and after digging through the rubble found the following bad transistors and need help finding substitutes.
Both Driver Transistors are bad 2SA566 and 2SC680
I couldn't find any of the suggested replacements, they must be obsolete as well?
I don't really wanna use NTE, but I guess NTE38 and NTE175 would work?? Any other suggestions?
Bias Transistor was bad 2SC496-O
Again, all I can find for a replacement is NTE295...any known replacements for this tranny that's available?
Power Protection Transistor 2SC735 was bad...
Only replacement I could find was NTE289A...again any better known substitutes??
I'm looking forward to getting this thing back together, hopefully NTE-less:yuck:
Soooo, I'd appreciate any help that you guys can lend :yes:
I don't really wanna use NTE, but I guess NTE38 and NTE175 would work?? Any other suggestions?Bias Transistor was bad 2SC496-O
