forzazzurri8
Hi guys,
I'm confused here I was hoping someone might be able to assist
I have a marantz 2275, the receiver has pre-amp outputs, as well as 2 sets (A/B) speaker outputs.
I have 2 Quad 11L bookshelf speakers and I am thinking of picking up a Focal Cobalt SW 800 sub which I am getting a good deal on. The problem is that the sub does not have line level speaker inputs and outputs, it only has a L/R RCA or single LFE input, what is the best (if possible) way to hook up the subwoofer? would I use y-cables to RCA on the L/R preamp section?
Any help would be greatly appreciated, thank you!
I wouldn't use tape output - the level never changes so you would have to adjust bass levels every time you change volume. The preamp out levels will follow the volume level on the receiver. Once you adjust the levels and controls on the sub, you shouldn't have to readjust them. Use the left and right inputs on the sub.
