Marantz 2275 power switch replacement?
EastPoint
Recycler
I have a 2275 with a toasted power switch, and I managed to physically break it while trying to get it open. It slots into a metal bar with a bunch of other push-button switches, so there's no way to just pop in a normal replacement power switch. Does anyone know where I could get a correct replacement? Otherwise I can try hacking off part of the metal housing to get a larger switch to fit.
Digikey part number EG1018-ND or EG1020-ND depending on the screw spacing.
Get a safety cap too PN BC2361-ND
I think these are right.
I don't know if that will fit into the slot. It has to go into the metal piece. Here's what I'm talking about. The power switch is on the left:
Is that a snap-switch? Maybe a pic or two from a different angle...
If it is, there's tons of replacements. Would have to get the old one out of that carrier thing. If those are rivets of some sort, might mean a bit of grinding, but that's what Dremel's are for.
Is that your switch or a picture of one like yours? After prying up the 4 tabs, can you pull it out? If that is yours, Soldering them wires back is going to be a pita. Unsolder the posts out of the boards would be the best way.
You said you broke something?? Was it the black part or the white stem?
OK, Your screwed:D Can you get it off by prying your four tabs up?
I would check ebay from time/time, but someone here may have one. If you cut the frame, you loose the ability to screw that end of the frame down.
Jonstigator's switch looks to be a good choice if you can take it off the frame and fit it into yours.
I got it out by prying up the tabs, but I was trying to get it open and I broke it. I had an idea about cutting the frame but leaving in the screw hole section, but I don't know if I can do it. I don't want to buy another used one because it will probably go bad eventually too.
