Rambling Man
Howdy!
Covid has finally given me the time needed to re-cap my 2325.
I had a great time combining my soldering skills with the joy this receiver brings to me.
After re-soldering/re-capping each board I would check all features for functionality.
My only issue arose with final adjustments. The bias for both channels is all over the place. The voltages were set on the power supply and amps after a 30+ minute warm up; set to Aux and volume at zero.
Offset readings range from 4.3 mV DC to -5.4 mV DC averaging .01 mV. I settled for the best average I could manage. When an amp gets “dialed in” the voltage tends to shift further negative over time.
Is it common to see such fluctuations?
Should I start by replacing the transistors at H701 and H702?
My main goal is to not replace every part as that’s a rabbit hole I prefer to not travel.
The only modifications made was to the PE-01 tone control board. The BA312 IC’s were swapped to the Sparkos Labs BA312-M modules... sacrilege I know!
These readings were read with a Fluke 87V on the min/max setting.
Thoughts?
Thanks,
Nick from Texas
Thoughts?
Thanks,
Nick from Texas
