Marantz 2325 Pre-out female RCA short no sound
richardg0n
Working on 2325 with left channel out. The sound output returned when I was using RCAs to test and crossing channels between Pre-out and Main. I noticed RCA was sensitive to touch on one of the Pre-Out RCA outputs causing the left channel sound to cut in and out. I used Deoxit D5 spray and Deoxit gold on female RCA inputs to clean faulty contact but the problem has returned. The unit will play for a while and the output starts losing sound on the left.
Advice is much appreciated.
Thanks!
Richard
Check solder connections.. RCA may need to be replaced.
