Hi all, my dad is doing a recap / rebuild of his marantz 2325 and we a few questions. So far he’s done the power supply board and one amp board. Our first question is does anyone know what the running temp of the big white ceramic resistor I circled in the pic? He also set all the voltages (idle etc). With the temp gun, his seems run between 140 & 180 degrees depending on where you point it. Does that seem normal or to hot for that area? And that’s after you play music for a while.
