Marantz 2325 recap list needed
sendust
Music feeds the soul
Hi guys a while ago i asked for a list of caps needed to rebuild my 2325, i did receive a list but Mouser and Dijikey had no way to cross reference. Does anyone here have a list i could use to pre purchase parts needed. I would like to rebuild and replace boards as i remove them. I like many tried to get the parts from irebuild but im not sure this is on the level anymore..
There is no substitute for going through your unit yourself and devising a list. Also, marking the negative end on the board, in case your board has an incorrect polarity noted. This has happened to me, whereas both the schematic and board had an incorrect polarity noted. In the end, I realized the negative polarity was to the board's ground plane and was able to to make the correction. Remember you can always go to a larger voltage and I usually do to ensure the lead pitch fits the board perfectly.
Lukiedog is right. Some Marantz manuals are infamous for being a bit off, or just downright wrong! Plus, some of the models were built over a period of several years and running changes were made. The updated pages may not be present in your copy of the manual. It is a good idea, as Lukiedog said, to go through and make your own list. If you have a digital camera with macro function, take some pictures up close of both sides of the board, too. If any values present are too far out from the manual, do a search and find out if it has been discussed- it probably has!
One example: I know of a couple of variations on the power board in the Marantz 2325. 90% of them use one type of relay, and others use another type (or maybe two). Different factories, different times, different suppliers of the board, running changes, etc.
Thanks i guess i was a little overwhelmed with accessing all the boards at once, I will just take photos along the way to put all parts back where they belong
