zedex
Well-Known Member
Hi. Anyone familiar with the 2325?
I am having a problem with the mode switch. The mode switch was corroded with green corrosion on one of the fingers that the disk contacts. So thats fixed but putting the switch back in i have a broken wire. I took pictures of the wiring with the switch out but not disconnected just incase during cleaning that a mystery wire would stop my progress. That didnt help as the wire must have broken off under the switch and under the rats nest of wires. Luckily. The wire in question is a lone heavy yellow wire that runs under the removable bank of 5 switches. It either connects to the mode switch or the selector switch right next to it. Its not obvious where this wire connects.
Here is a picture of the yellow wire in question that runs under the bank of 5 switches. You can see the mode switch above it.
Heres another pic of mystery wire. You can see the yellow wire with a piece of black heat shrink on it.
I pulled the wire up so it can be seen, otherwise the wire was i think below the switch somewhere.The bank of 5 switches is in place in this pic. Any help much appreciated.
Cheers.
Cheers.
