richardg0n
Greetings AK Members,
Working on a 2325 restoration/recap and asking for your guidance. I have rebuilt/recapped the power supply P800, PE01 Pre amp, P400 Phono amp, PU01 Multipath, and PH01 Buffer amp board.
I have restored several 2325s, and this is the first time I am experiencing an issue with the right channel. I suspect the problem may be from installing the notorious cap at CH13 with the polarity reversed on PH01(buffer amp assembly). I installed a new cap at CH13 and replaced a smoked resistor at RH28.
Everything seemed to be working correctly, including The left and right channels. I then moved on to recapping the P700 right amp board. The trouble began once I completed the recap of the P700 right channel. There is no audio on the right.
Here are the steps I have taken so far to troubleshoot.
1. Crossed the pre and main RCA's in the back, and there is no output from the right main.
2. Removed output transistors from right amp P700 and tested with a multimeter in diode test mode. All four are working and in spec.
3. Used oscilloscope to trace the audio path through the pre-amp PE01, and there is a good signal going through and out of the pre-amp.
4. Verified there is power from J809 on P800(power supply) to the right amp.
5. Swapped out right side p700 from another 2325 and still experiencing the same issue.
How would you troubleshoot this? your input is much appreciated.
