Took the bottom off my 2330 to get to the pots with some Deoxit a bit better, and noticed the 2 large filter caps have a slight leak.
Needless to say, I'll be replacing these before anything else.
Is there a recommended replacement cap/part for this unit? Looks like they're both 75V 15000uF... this was on each cap:
75v 15000
Surge 95v
Red positive
Ece-gm75v153z
+85 degrees
372
Never had to order/replace these before. Do I essentially unscrew the bottom connectors and top "rings" that hold them in place, and simply reinstall the new ones? Just want to be sure it's as easy as I think...
Thanks again guys!
Needless to say, I'll be replacing these before anything else.Is there a recommended replacement cap/part for this unit? Looks like they're both 75V 15000uF... this was on each cap:
75v 15000
Surge 95v
Red positive
Ece-gm75v153z
+85 degrees
372
Thanks again guys!
