Redkarter
I purchased this 2330 in non working condition from an electronics recycler some time ago and tried my best at cleaning it up. Everything went rather well, it does look and sound great with lots of power to spare.
Unfortunately there is a slight pop on turnoff. Also a very quiet, possibly 60hz buzz that does not increase with volume. The pop does exist when changing the speaker selectors after the unit is on.
The bias, offset and ps voltages have been set. I have recapped the amp boards, power supply, tone, dolby, phono board and replaced the main filter caps as well. Mostly with the same value caps and only the electrolytics. I have checked over all of the grounding wires and their connections, cleaned and bypassed the powerswitch. I have also cleaned the amp connectors. Some things I have not done: changed the relay in the power supply. I have not put bypass caps at the filter caps or a new snubber cap for the power switch, although the old one is in there.
I have been enjoying this beast otherwise and its currently hooked up to a pair of heresey and pioneer cs63dx and powers all 4 to unbearable volumes.
