So my friend called me up today and was very distraught. He purchased a Marantz 240 and 7t preamp a few months ago and was experimenting with some separate phone preamps he had. The problem came when he was switching around the phono preamps with the amp and stuff on and accidentally hit the RCA output cable from the pre to power amp. When he did he said there was a loud crazy sound and he jumped up to switch off everything. He said he though it may have been a corroded RCA terminal so he cleaned the RCA jacks with deoxit and hooked everything back up. When he did the sound was extremely weak so he plugged in his headphones to see if the issue was in his speakers. He he did there was another loud popping noise from the headphones and no more sound from speakers at all after that and the relay no longer clicks on the power amp.
He called me because he knows I work on vintage equipment but solid state is not really my forte, I mostly work on tube stuff. Ive worked on solid state stuff before but mostly just simple recaps and stuff like that. My question is, what would have blown on the Poweramp by accidentally shorting the RCA cable from the preamp? I'm leaning towards the outputs because of no sound but if there's another place I should look I'm all ears. Also is it likely, if the outputs are blown, that other stuff down stream may have been damaged as well?
