elgrillo
El Grillo
Hello I have a doubt about biasing different versions of Marantz 250 power amp.
1) I note that there is a version 1 (mk1) that the manual specify to bias the amp with a wattmeter and a voltmeter.
2) As seen on bulletin m-250-3 the specify to adjust bias using a multimeter reading Mv (between 24-30mv) across R531 & R532.
In service bulletin m-250-4 they also specify adjusting bias with a multimeter in the same resistors but between 12-15 mv.
Im trying to bias my Marantz 250 (mk1) using the method of the bulletins because I don't have a wattmeter. but the bias drifts. Normally it stays around 13 mv, sometimes it can go up up to 17mv or down till 10 mv.
My question is , as the mk1 was the first version of all , is this one is prone to drift bias a little more , and that is why they made the revisions?
I saw a video in youtube of a guy restoring a Marantz 250m and when he biased the amp, the amp stabilized really nice in 12Mv and didn't drift more than a few decimals.
My Marantz have been recapped , new transistors replacements, and a few new resistors on the amp boards . I changed some resistors on the power supply, al caps and changed the relay and diodes. I just left the original transistors transistors.
Maybe somebody that worked on all versions can tell about the difference on bias stability between the different versions of the Marantz 250.
Thanks in advanced.
Gonzalo.
Thanks in advanced.
Gonzalo.
