Hi all,
I have a 250 that I completely restored recently thanks to the help from several AK members who guided me through it. The amp works flawlessly except for one issue that it has had ever since I got it.
The needle movement on the left channel VU meter is less than half of the right channel VU meter needle movement. I did the meter calibration as per the service manual and the right channel calibrated just fine but the left channel won't calibrate, it will only adjust to about half way to 0db. When playing music if the right channel is at -2db the left channel is at -12db that's how much of a spread there is between the two needle movements.
Both channels are putting out equal volume so its not the left channel. I rebuilt everything in this amp except the meter board. I also noticed if I turn the left meter off, it doesn't turn off, it drops a little but still has movement when music is playing, but if I turn off the right VU meter then they both turn off.
The left meter is not sluggish or sticking and I can peg it if I increase the output of the 1KHz sinewave, so I don't believe the meter is defective.
Is it time to rebuild meter board or could it be something else causing the left channel VU meter to not be performing equally to the right channel? Any input would be greatly appreciated.
