Hi all,
Just acquired a very nice 250 S/N 9497. According to the previous owner he replaced all the caps on both amp boards but said he forgot to reconnect the pigtail on the bias transistor on the right channel heat sink and ran the amp which in turn cooked 3 of the output transistors.
I'm going to replace all the outputs with MJ21193/94 which I have several of both on hand. The service bulletin M-250-2 says the HFE range should fall between 50 - 100. All of my MJ21194 except one are below 100, mostly in the 70's range. All of my MJ21193 except for one are above 100 mostly in the 103 to 109 range.
My question is can I safely use the the MJ21193 that have a HFE above 100 or am I asking for trouble going above the bulletins recommended range of 50-100?
