phatterplatter
Hello techies
I have a clients 250 here. One side is fine and adjusts per spec
The other side has over 4.00 DC on it and I've replaced a number of the smaller lytic caps and the first pre-driver transistor. It still has over 4.00 vdc out . The power transistors are ok with the exception that one has quite a bit diff gain than the others. Would THAT be the culprit?
Thanks
Thanks
