Dingle7492
I have a Marantz 2500 that all seems to work OK, however the Scope is not working. It does have a glow. I went through and tested most of the voltages and am seeing some major discrepancies.
Attached is a photo of the voltage readings. I am new to this, hoping some guru can at least get me started on some specifics to check. I did replace the transistors, 4x SK30's and I replaced the heat shrinked 2SC1507's with new MJE15032G's. Any help would be appreciated!
