Halisson
Member
Hey, guys,
audiokarma taught me a lot many times. I am grateful for all the help I have ever received.
I'm having a problem with a Marantz 2600 that I really don't know what else to do.
The device arrived with a burnt transformer, problems with the FM stereo (after changing the (q301)HA1156w, stereo light on, 19khz on), then difficulty displaying the FM scope via Display Tunning or Multipath (I changed QR51-Upa63h to Upa68h ) and it was good. Upper and lower L201 coil, service manual specification, fine.
Scope alignment was done using 3cm horizontally and vertically with 150mv, and that's fine, aux for example.
Scope->Multipath and Tuning, AM and FM mode, and everything was fine.
Scope->Audio, Phono, Aux mode, AM mode, and that's fine.
Scope->Audio FM/FM 25us, in reverse or stereo modes, tilt and incorrect display.
Scope->Audio FM/FM 25us, in L+R,L OR R mode, screen tilt is ok.
You may notice a slight difference in L and R, see images.
I am attaching a photo of the modes and what I have here.
Several of the P200's capacitors have been replaced, FM tuning is excellent, and the stereo runs nice and strong (like other Marantz 2500s and 2385s).
Adjusting the R319, I get the two output levels (monitor out 1), the same levels and the same phase. Q302,303 and 304 have been replaced.
As described, use on FM or FM25us does not change the symptom of the problem. Quartz lock working well, including mute/quartz function.
It's a device that went through another technician, I'm fixing what I see.
I appreciate his help.
