Marantz 32 and 33 pairing?
Rusty Coleco
Hello all-
First post, so please pardon me if this isn't the correct place to do this - I'm new to the forum, so any advice or direction is greatly appreciated.
I recently came across a Marantz model 32 power amp, and matching preamp model 33. I've never used preamp / power amp separates before, so I'd be really appreciative of any info you could please give me. Does the 32 even have a power switch? Does it power on with the 33? Any advice on how to connect these components would be lovely.
I know these are silly questions, but figured I'd get he best answers to my question on this site, so here I am.
Thanks for your time!
I have a 33 and in the back it says "500V max" on the switched section so arguably it could be used to turn on the amp. My 240 doesn't have a power switch either. The 33 is well regarded as an excelent preamp, mine is totally original and I am going to recap it. Another suggestion of course is deoxit it.
https://audiokarma.org/forums/index.php?threads/the-idiots-guide-to-using-deoxit-revisited.207005/
The 33 is similar to the 1120 power section as I remember reading here. It could give you up to 80 RMS/channel on 4ohm which is pretty respectable.
Those should have been produced in the US and they are fairly easy to work on if need be.
How do you power on/off your 240?
I don't have the heart to plug it into the 33 because the 240 is rated to almost 300RMS total but in the case of the 32 I think it should be OK to plug it in the back on the switched section. I am assuming they are all in good working condition. If they were truly designed as a pair I think it would make sense.
I basically have a power cord just for the 240 with a switch. I may need to find a better solution or assume the 33 can take it.
Marantz 240 power consumption is 480W according to SM. So it will be very close to the maximum limit of 500W
I restored a 33 and a matching 16 power amp. The 33 preamp does sound very nice. I switched to tubes about 7 or 8 years ago and recently sold the 33 and 16. They were part of my main rig until I switched to tubes. I really didn't want to get rid of them, but they just weren't being used anymore. It was better to pass them along to someone that uses them than just sitting rotting on a shelf.
@Lavane - The one I have is a totally original from the first generation, with FETs. How far would you recommend restoring it - the unit is working, so my first thought was to replace the electrolytics and tantalums.
I replaced all the electrolytic caps in all the sections including the headphone amp and center channel. I replaced the tantalum caps with small electrolytic's, but wima stack films would do also. Everything else tested good. I did remove the transistors on the two tone boards and clean the leads since they were in sockets making sure each one went back in the same socket they came out of. I didn't mess with the RCA jacks either since mine weren't corroded. And of course cleaned the pots and sliders since a couple were a bit scratchy, and used fader lube on them after.
I don't think there was much more that I did. I used Vishey axial caps if I remember right. There is one 16uf axial, and since that's a bit of an odd value now, a 22uf will due just fine. The new owner is very happy with the set. Just check the orientation when it comes to the tantalums if using lytics to replace them. The silk screen printing on the boards my be wrong. I can't remember if they were right or not on that one. It is a lot of disassembly with the 33. Each channel has its own tone board, and the other sections can be a bit cramped.
@Lavane thank you for the information. I will do the same. I have Elna Silmics but they are radial and I think they may look odd although sonically I like them. There are indeed some odd values like 32uf which I plan on using 33uf it shouldn't make a difference given the tolerances.
Do you remember disconnecting the boards or were you able to work on them without desoldering the wires? Thanks again.
I was able to get to everything on the tone boards by removing only one shielded cable if I remember right. I had to remove the mounting screws on the pots and pull them back and out to get to more of the boards. The tone boards are the easiest. The headphone amp on the right side took a little more disassembly to get to those caps. Radial caps may not fit in some areas if you choose to use them. The small diameter radials are what you would use to replace the tantalums though. Just measure the space before ordering. Other than the tone boards, everything else is pretty compact.
You might want to get the service bulletins and make those changes per serial number also. Mine must have been a later model. The owners manual that came with it had a nice fold out schematic and a list of all service bulletins. The original manuals for these are great.
Thank you. I will try to get the bulletins online. Not sure if the pdf I have contains them. I was looking and you are quite right radials won't fit - back to Mouser...
