I've recently picked up a 4140 as my first proper amp but its having some interesting issues.
Starting the amp up using the Aux channel with a cell phone connected works great. As soon as I switch to phono channel with my turn-table hooked up, audio is very quiet and I get some subtle popping/static noise.
Going back to the Aux channel from the Phono channel, the audio is quiet like in the phono channel. I can also subtly here the phono channel leaking through. When I unplug my phone and plug it back in, the volume goes back to normal.
So far, I've thoroughly cleaned all the pots, and replaced the 1uf caps on the preamp and phono board.
I'm pretty savvy with working on electronics, but this is my first amp repair.
Any ideas what could be causing this or where I should be checking? Any tips or info would be greatly appreciated!
