daveyh
I am having problems with one of my Marantz 4230 amplifier boards. I recapped both boards and recapped the power supply. I have also replaced all the transistors on both boards. I used TIP31CG for the outputs. I have pulled and checked the diodes and resistors. I have not replaced (but have on order) the 0.5 3w resistors R759-R762 and though the seem to check out OK I will be replacing them when my order comes in from Mouser.
My problem is that the right channel keeps burning the R747 resistor. It runs for awhile and when I turn up the volume, POOF. Magic smoke. It runs fine and my DBT does not show a short but when I plug it into current that's when it happens. It also takes out fries the two TIP31CG outputs.
Any one have an idea as to what is going on?
